Return to Index
Read Responses
You'd be two "targets" on top of one another
In Response To:
Not sure, but...
The software displays the position -- it doesn't "blink" each time it updates.
An interesting AIS transponder question
You'd need to study the electronic protocol of AIS to determine that
I believe...that the MMSI isn't the key
Not sure, but...
If each unit is sending the same data it seems it would be a single target just updated twice as often
I believe it's like sending the same text from two emails
I was wrong about the slot info...
You may be right (and I may wrong)
