Yes... It's basically a Newport with...
a pilot house. Designed by C & C. It is an encapsulated keel. IIRC, the keel bolts are encapuslated in epoxy after installation. You need to chisel it out to access the bolts. I drilled holes in various places on the keel including the bottom and no water has ran out, so I'm assuming the keel is dry.
