I would get the angle grinder out and have at the bad areas...
In Response To: Keel help... ()
Grind back to good glass and reglass. Not a tough job. If you are worried about the keel shape, make templates before you start grinding and use then to refair after you finish glassing. Glass work is easy, if a bit messy and itchy.
