Return to Index
Read Responses
At the fitting or a crack in the body or at the tube or?
In Response To:
the leak is at the injector pump - any ideas
yanmar 3qm30 question
Smell?
green antifreeze...
here is where it is...
I once had oil overflowing from the injection pump...
Check your bleed screws.
yes, I did that - unscrewed it, bled it and still leaks.
Weird it is all three. Did someone loosen all these recently?
no - it may be only one that is leaking, but with the engine running and me bent over with a mirror and ..
This Thread may Be Helpful, J
