Easily translated on "google Earth"
In Response To: Those are UTM numbers... ()
Easiest way to translate Lat/Lon ---->UTM.
Use "Google Earth" Application (free download if you dont already have it).
Change 'preferences' (in one of the application pull-down menus). Then, change from Deg.Min.Sec to UTM) on Google Earth application, then zoom-in to 'close' to the location you are looking for ---- while watching the POSITION BAR at the bottom margin (bar) of the Google Earth map/chart
