Return to Index
Read Responses
Most I've seen are in main bulkhead beam or bulkhead so you.....
In Response To:
Where do you put your documentation number?
..see it when you come below. Routered in seems common to me.
Mine is in the engine room fiber glassed to a tank.
Ours is routed into a beam under the companionway behind the ladder
The regs say "permanently attached to the main bulkhead"
Mine is glassed-in to the hull skin beneath a main cabin sole hatch
a place somwhat hidden
Two places
Also good idea to 'engrave' HIN in a hidden place
I carved the numbers on
That sounds nice... I'm just trying to figure out why folks hide this stuff
Seems to me
Exactly... that was what I was thinking...
As you can see in a previous post, mine
