Return to Index
Read Responses
Also good idea to 'engrave' HIN in a hidden place
In Response To:
Two places
just in case the boat gets 'stolen'. Then its quite easy to prove 'ownership'.
Where do you put your documentation number?
Mine is in the engine room fiber glassed to a tank.
Ours is routed into a beam under the companionway behind the ladder
The regs say "permanently attached to the main bulkhead"
Mine is glassed-in to the hull skin beneath a main cabin sole hatch
Most I've seen are in main bulkhead beam or bulkhead so you.....
a place somwhat hidden
Two places
I carved the numbers on
That sounds nice... I'm just trying to figure out why folks hide this stuff
Seems to me
Exactly... that was what I was thinking...
As you can see in a previous post, mine
