Remove the pump from the base and take it home to rebuild it. Only two hose connections and a few bolts to remove...put on a sheet of plastic where it's nice and warm...bring it back next spring.
However, you don't have to spend anywhere near $400 to upgrade to a PH II....check this out: http://shop.sailboatowners.com/detail.htm?group=1357&cat=1002
