Not trying to be a wise-guy, but I'm sure it's a bit difficult at times like this. It's 8 degrees F as I write this and the weatherman says it will hit -3 tonight in southern CT. Obviously it's a bit chilly as evidenced by your "project". What are you using to heat the boat? Is the boat warm enough, overall? Would you do this again for another New England winter?
