For bilge pumps and bulge switches (and fresh water pumps)
I've started to standardize on the WM house brand, which is currently made by Johnson Pumps. Why? Because they tend to have a high failure rate and WM will replace them with a no-questions replacement from store stock, and there's a WM not too far from wherever I sail. I like the WM/Johnson solid-state bilge switch too (no moving parts and it mounts right to the pump with a click).
For holding tank pump-out I went for the most reliable I could find (a Dometic SaniPump) because that's a job I don't want to do again as long as I own this boat.
