Those window were seven feet long, single piece of acrylic. I surmised the expansion and contraction coupled with a single bolt at each end led to leaking almost inevitably. Therefore I made each side in three pices as there were landings in between areas. Worked well. I saw the boat a year ago and after nearly ten years still no leaks with that good cleaning and Dow 795.
