I could check it out.
The only thing I don't like about the boat is the 'crawl through' to the rear stateroom. It makes the boat low but for a guy like me that's 6'4 it's not a good choice. If you're anywhere less than 6' you could probably get use to it.
There are some good boats here if you aren't against a bit of work. Most are about 1/2 what they would be in the states in the same condition.
