It was 16-degrees F when I awoke this morning and it's up to 19 now. Hard to believe it will be only weeks until April and then we start the Spring prep. The bottom only needs one coat of Hydrocoat and a second coat in the high-wear areas. But the big job is is the topsides -- I need to remove the Poli-Glow, then wet-sand, compound and wax the topsides -- it's like doing three 40-footers. This is a downside to a trimaran.
