Return to Index
Read Responses
Hi Peggy, Thanks. I'm set up to flush
In Response To:
You can use most anything to clean the bowl--IF you don't flush it
with both fresh and salt water. I'm thinking that I wouldn't need any other connections??
Peggy, I just finished installing the Raratan Marine Elegance
"When I'm out there cruising",
Well Dan, it looks like you can
Wanted to have everything finished before you arrived
I don't know what she will do. The baby
Thanks for that Peggy. WOW Steve ...
Lay out was very time consuming. I
Cool ... thanks for all that Steve ! cheers, John
You bet, good luck.
yeah, I thought that was one of the advantages of sea/fresh upgrade ?
With the Sea Fresh option, you're good to go...
Thanks Peggy, I'll remember that.
