Return to Index
Read Responses
got an impact driver..worth a shot.
In Response To:
got a drill?
Fruit high tech British style
Frozen SS screw in an aluminum frame, looking for suggestions ....
got a drill?
It's a tough task, but I agree on the impact device.
Additionally on threaded stuff...sometimes you can improve things by...
That's what I do
Try and remove them with the impac driver and
If there would be ...
Jumper Cables
You saved me the trouble of describing the jumper cable trick
What do you typically use for a battery?
Just a Group 24 or 27 Cranking Battery works fine.
When I was working I had to check
Try a GraBit Damaged Screw Remover. Worked well for me
Oh ya, make sure you've soaked the threads in a penetrating oil
Canned Air?
I don't think you'll break the screw.
