We never had a good spot for that before. It's a bit small but adequate. It tilts out. There's a latch stop on the back that holds it open, empty or full. To remove, flip the latch and it comes out allowing better access to the sink seacock and a few other things.
Push it back in and gravity closes it and holds it tightly closed. There's a lot of sketch work in getting things to work. The oven door clears. The bin will only open a few inches on port tack, but is over wise unhampered.
