Oh no, NEVER use epoxy with Teak
In Response To: Epoxy ()
Oh no, NEVER use epoxy with teak.
Teak expands and contracts as the moisture level changes and each time it splits a little more from the fiberglass until it is quite loose.
The bond between the teak and fiberglass has to be flexible and remain flexible.
Any good quality marine cement that is compatible with both and remains flexible will allow the teak to expand and contract without splitting the bond.
