All right, use forward then . . . if you have a feathering prop, a few seconds in gear either way will feather the prop and then you can shift back to neutral.
Works for us, anyway. Water pressure on the prop is not likely to turn over a diesel engine!
--Karl
S/V Mabel Rose
