The GPS receiver is within the box, so there is no nmea connector for incoming GPS data, just an antenna connector. Probably by design, since the spec requires a separate GPS. For mine, I installed the antenna near the other external GPS receiver on the stern pulpit, and ran the wiring along the same path to the AIS.
