buy a mechanical pressure gauge.
1/8 pipe thread. remove the sensor and spin in the mech gauge. the truth will be known. With 4000 hours you might have some wear in the main/rod bearings that will allow the oil pressure to drop at idle when the oil is hot. ALSO change your motor oil at least once a year.
