..yet is flexible to bend. The metal is narrow on the opening and thereby clings to the surface you wrap it on. It's common in production boats in use below.
If you have tools such as a saber saw and router and are a bit handy you can make rigid ones from Starboard/marine board or teak or whatever fairly easily but with diligence.
