where was the corrosion?
In Response To: Charging problems ()
At the battery terminals? the alternator?
Just had a friend think he needed a new starter solenoid when it was just corrosion at the battery terminal. On quick check they looked good, but on closer inspection that was the problem (of course it took 2 weeks to figure it out).
