I checked the battery terminals but they were all good
In Response To: where was the corrosion? ()
The alternator mounting was bad so I wasn't getting good ground but the positive wire ring terminal at the alternator was bad too. I also cleaned up the connections at the ignition switch and checked the battery switch.
