It all goes overboard.
In Response To: ElectroScan (LectraSan) ()
The LectraSan has a high amp requirement but it's for such a short time that the electrical use is negligble. These units are flow through so you don't need a Y valve. Just pump your head without running the unit and the effluent goes overboard untreated. I suppose a Y valve would have a use if you wanted to remove the LectraSan for maintenance or whatever.
