Take a T with - out any thing between the T and the exhaust, and run the hose to to the something like the cockpit thru hull. Tap into it and put a fitting in there. Then when the engine shuts down it will be impossible to create a a vacuum in the exhaust line, air will slide right in and break it.
Go Slow
Sail Far
Stay Long
