Point Judith Pond
I sail out of PJP. I draw 5' nominal and go in and out all the way up to the north end no problem any tide. I avoid low low at moon tide but otherwise no problem. With 6' draft you would definitely need to play the tide for the channel north of the marinas on the west side, and choose your anchorage with thought. The tidal range in PJP is around 2 ft.
