Return to Index
Read Responses
A 2'long pickle grabber would have to be the handiest tool EVER on a boat!
In Response To:
Follow Up: Success
Glad it was that easy to solve.
Get Rid of Boat Odors!
Removing object from Raritan PHII bowl?
Options
Get a wet-dry vac
Could mebbe attach a flexible and as big a hose type as possible to get closer to the cap.
Y'all sure do know how to do things the hard way!
To get to the base plug...
Several replies at once...starting with Labatt's problem
Thanks for that response... one thing I noticed however was this common element...
P.S.
I'm a little confused?
I don't think it went far, but murphy may be lurking...
STOP Pumping -- nothing good can happen at this point until you get the object out.
Yeah... I yelled stop when they were on the upstroke
(that's what she said)
"longer than a year since the joker has been replaced"
Just has to be...
I thought the joker was the person who dropped the cap into the bowl!
Great diagram Peggy.
Follow Up: Success
