Return to Index
Read Responses
so basically you have this ...
In Response To:
Either the alarm temp sender, or the alarm itself.
warning system that doesn't work. Why would a new one be any more reliable?
... and speaking of on-board alarms, Steve D'Antonio's has a good article in June CW ...
Interesting. My engine started to overheat the other day, and the alarm did not go off.
What failed Tom ...
Oil senders
Is there a way to test a Low Oil Pressure Alarm ...
Isn't newer always better?
No! In fact I give maybe, 50/50
Basically. It's just two redundant, oil and temp senders and alarms.
Second Alarm
I had a similar experience with the Borel
