Almost any control will work with the drive...
In Response To: Autopilot ()
they are pretty standard, as long as it is rated for enough amps to drive the motor.
I would encourage you to look at the X series Raymarine on any equivalent modern controller that has gyros - these steer a far better course, particularly downwind in bad conditions, than those that came before. The difference between the new ones and a 5000 will be dramatic.
