While doing an engine check I noticed that the salt water pump was leaking. The pump was rebuilt in La Paz about three years ago. While the mechanic was repairing a small oil leak on the front of the engine I had him replace the old saltwater pump with the rebuilt one. I should have left well enough alone! We came back in, replace the pump and drove back down to TJ and did the check in paperwork so we can bypass Cabo. Yes, it was fun last night. Maybe we will see you again sometime. We are going to give it another try in the morning. Best of luck.
