Try it first before you glue it down.
In Response To: Why couldn't I... ()
Put the transducer in a baggie with water. Put a dab of grease or vaseline on the inside of the hull, then put the transducer/baggie against the grease. Once you fine a good spot, clean the hull & transducer then secure it in place. Silicone should work fine, but not as permanent as epoxy.
