Yikes! I have to go up in the lift on my boat to work the centerboard.
I'm not worried about the boat dropping completely, but I'm aware the nose can slip. They're very careful here and lash the slings together to prevent a big slip.
But you have to assume the boat could shift so it's crazy to go ondeck. I assume a violent movement and position myself securely. I'm used to working around stuff that moves....
