Return to Index
Read Responses
If you don't have an apparent wind function, then you won't be able set the Autopilot on "Wind"
In Response To:
I have a mish-mash
Autopilot choices?
I use Simrad
What sailing instruments do you have?
I have a mish-mash
That's true however, on the bright side
Alpha 3000 is tops!
Thanks Ron! That is one beautiful boat!
My Alpha has...
The simplicity appeals.
Alpha Spectra
Thanks Eddie! I think I'll
Drive the Monitor with a small tiller autopilot?
