Return to Index
Read Responses
Thanks Eddie! I think I'll
In Response To:
Alpha Spectra
look into Alpha a little deeper.
http://www.novascotiawebcams.com/south-shore/bluenose-ii.html
Autopilot choices?
I use Simrad
What sailing instruments do you have?
I have a mish-mash
If you don't have an apparent wind function, then you won't be able set the Autopilot on "Wind"
That's true however, on the bright side
Alpha 3000 is tops!
Thanks Ron! That is one beautiful boat!
My Alpha has...
The simplicity appeals.
Alpha Spectra
Drive the Monitor with a small tiller autopilot?
