The windlass is factory filled with Shell Mytilus "A" grease. FYI, they recommend Shell Alvania or similar for the grease nipple and a few drops of oil to the Operating spindle. I hope this helps. P.S. If you need an exploded view I can send you the PDF.
Cheers, David
