Easier to test the shore power than the charger
Have you plugged in something else direct at the dock? Could it be your shore power cord? If the cord, sometimes you will get a good reading with a voltmeter but it won't carry enough current to power a load. Check your connections for corrosion. If everything isn't bright and shiny re-do your connections or try someone else's cord.
