I've used magic marker on my PVC Zodiac for over 10 years. Still seems fine. Magic marker is really preferred to those number boards - if someone borrows your dingy and cuts off the number boards, the number is gone. Yes, the MM numbers fade in the sun - redo as needed. They last much longer if you keep the boat covered when not in active use. Oh yeah, the boat will last longer too!
