Or drill and tap a hole in the existing fuel level sender plate. Actually my moeller tank on Seaquestor has the return on a "T" on the vent. It works just fine as long as the vent outlet is 12" or so above the top of the tank. Most of the vent fittings are for 5/8" hose with a 3/8" pipe fitting on the tank.
