fuel pump
In Response To: Your Autohelm what? ()
I want to install a 12 volt Carter fuel pump in line with my Volvo fuel pump so that I can vent the system with a lot less effort, and use a by pass valve for fuel polishing and also have a back up pump in case of a pump failure. With the elect pump not running will that cause a problem for the mech pump pumping???
Thanks for your help
Mike
S/V Wigwam
