Return to Index
Read Responses
Cool, apparently I am thinking down a good path.
In Response To:
Exactly what I installed when I cleaned up the wiring.
"cleaned up the wiring." Got it, and exactly what I had in mind.
Ever hear of a Danforth battery monitor?
So you had a wiring problem Gene, not a dead battery?
I'm interested also.
Well I did it via the battery switch, but yes.
basically a loose connection.
I use a "power Post" for both my positive and
I like the "boot" that is shown with those... but not quite sure what the Power Post is...
I am thinking I need something more like this...
it got to the point where I almost couldn't put the screw on.
Danforth
Thanks... do you have any documentation?
Documentation
OK thanks... I'll take another look at the back of mine...
