Tom, went over TD with a knowledgable guy.
There's a guy here at Port A that lives on his boat and winterizes a lot of boats. We didn't have much time but with the help of the board and his experience I believe it will be fine. It seems that the most difficult part of the job is the 15 gallon water heater, draining and bypassing it so we don't need 15 gallons of antifreeze to fill it. It's not an easy water heater to bypass.
Starting the engine and generator while on the hard is going to be very strange but then they only needs to run about 30 seconds. Glad I'm not going to be there for that.
Again, thanks to the input from the board I was able to intelligently discuss the process instead of being clueless.
Thanks guys,
Dan
