I would check the connector for the trnsducer where it plugs into the display. Clean the contacts and the problem may (hopefully) go away. If it isn't a poor connection then you likely have a bad transducer or cable. When my Datamarine depth sounder died I replaced it with a Raymarine ST-40. I have been very happy with the Raymarine.
