Return to Index
Read Responses
The ground plane radiates the same signal as your antenna...
In Response To:
SSB ground foil and Autopilot wiring
It is half of your antenna afterall.
Not so simple
Why not just hand steer when using the SSB?
That's what we've always done in the past Dan ...
Let us know what the end result is.
I would do your first Paragraph then test.
