Return to Index
Read Responses
Tef Gel is lanolin-based
In Response To:
Corrosion protection for internal engine flange and bolts
I'm not sure about the temperature range of that. I use Super Lube anti-corrosion gel or grease
http://www.super-lube.com/super-lube-anticorrosion-gel-ezp-199.html
Larry...
Thanks for the correction
Are you sure about that?
No.
