So finishing up installation of a new poly tank. That required pulling the engine out of the boat, so it is getting an overhaul as well as starter motor, alternator and SW pump rebuilds and all new engine hoses, new damper plate and tranny. Will be installing a new autopilot (Alpha 3000), Vesper AIS, and Navtex. Doubling the batttery bank, adding fuses near the battery, redoing SSB wires and grounds, adding tabs on transom for Jordan drogue.
Those are the projects I'm working on this month. I'm sure new projects will come along to add to the list just as I think I'm ready to call it good.
