Return to Index
Read Responses
First thing I ask myself, does the bolt appear to be a part of a bolt pattern?
In Response To:
Seacock problems!
Are there other bolts? Of the same diameter? That sort of thing.
Seacock problems!
http://www.perko.com/product_listing/underwater_hardware/2/40/
I think the.careful vice grip is right.
Todd, are the two or four bolts in the plate? Is only one of the four loose?
That's what I would do.
In re-reading I'm curious
Before you try to tighten...
Is the boat out of the water?
yes, boat is out of water.
Ah, piece of cake then. Haul it off'n the boat, rebed it for security.
Perko sea cocks
FWIW... Maine Sail has a great writeup on this
