..somewhere in the application amount and in the rolling out time there is a relationship that can alter the final finish. Remembering that it is designed to cover 80 sq. ft. per GALLON it may be that laid on thicker would take less rolling, hence fewer peaks as the weight of the added thickness would slump earlier in the process if not rolled so much to cover.
I don't go barefoot, bad feet'ish, so agressive'er will work for me.
I have two sections left to do on the Kiwigrip but laid off over the weekend. The job will have taken three quarts to do my somewhat large deck area for a sixteen foot boat. Photo is a before while primer was going on for the color borders.
