Return to Index
Read Responses
Belt on the way.
In Response To:
Mine did the same thing a couple years ago, Dave.
Simplest option to be sure.
Maine a long way, hand-steered.
Hopefully its something simple
Yes on the fog! Noticed that once.
I did exactly that with my last boat
Looking now at the insides. Idler tension hard to adjust.
Two working wheel drives available.
Emailed. You there?
Wheel drives
Belt on the way.
Keep us posted Dave
That's a bit different.
flat rate rebuild
Thanks for the support!
Your posts are sometimes like jigsaw puzzles, Dave.
Back when working, was known as "cryptic."
