According to the sailcalculator http://www.image-ination.com/sailcalc.html the immersion rate for your IP27 is 960 lb/inch and has a design displacement of 7995 lbs. The same site says mine is 721 lb/inch and I'm about an inch lower than my design water line which sounds about right considering the extra gear I have.
