the sink is a Pullman fold-up type and we don't use it much.
I am going to put a check valve and vented loop into the fresh water feed to stop salt water from getting into the fresh water lines. Won't be a problem when using the fresh water flush, which will be pressurized, and thinking about it, when short on fresh water and using salt water I could have a shut off valve on the fresh water line.
